Kod: Zaznacz cały
# servo
servo 1 1000 2000 1500 80 0
Kod: Zaznacz cały
# servo
servo 0 1000 2000 1500 100 -1
servo 1 1000 2000 1500 100 -1
servo 2 1000 2000 1500 100 -1
servo 3 1000 2000 1500 100 -1
servo 4 1000 2000 1500 100 -1
servo 5 1000 2000 1500 100 -1
servo 6 1000 2000 1500 100 -1
servo 7 1000 2000 1500 100 -1
Kod: Zaznacz cały
# servo mixer
smix reset
Kod: Zaznacz cały
# feature
feature SERVO_TILT
feature TELEMETRY
Kod: Zaznacz cały
# feature
feature -RX_PPM
feature -INFLIGHT_ACC_CAL
feature -RX_SERIAL
feature -MOTOR_STOP
feature -SERVO_TILT
feature -SOFTSERIAL
feature -GPS
feature -RANGEFINDER
feature -TELEMETRY
feature -3D
feature -RX_PARALLEL_PWM
feature -RX_MSP
feature -RSSI_ADC
feature -LED_STRIP
feature -DISPLAY
feature -OSD
feature -CHANNEL_FORWARDING
feature -TRANSPONDER
feature -AIRMODE
feature -RX_SPI
feature -ESC_SENSOR
feature -ANTI_GRAVITY
feature -DYNAMIC_FILTER
feature RX_SERIAL
feature TELEMETRY
feature OSD
feature AIRMODE
feature ANTI_GRAVITY
Kod: Zaznacz cały
# serial
serial 2 64 115200 57600 0 115200
serial 5 0 115200 57600 0 115200
Kod: Zaznacz cały
serial 20 1 115200 57600 0 115200
serial 0 0 115200 57600 0 115200
serial 2 8192 115200 57600 0 115200
serial 5 64 115200 57600 0 115200
Kod: Zaznacz cały
# aux
aux 0 0 1 1600 2050 0 0
aux 1 1 0 1325 1775 0 0
aux 2 2 0 900 1275 0 0
aux 3 8 0 950 2050 0 0
aux 4 47 0 1800 2050 0 0
Kod: Zaznacz cały
# aux
aux 0 0 1 1300 1700 0 0
aux 1 13 3 1300 1700 0 0
aux 2 26 0 900 1300 0 0
aux 3 31 0 1300 1700 0 0
aux 4 0 0 900 900 0 0
aux 5 0 0 900 900 0 0
aux 6 0 0 900 900 0 0
aux 7 0 0 900 900 0 0
aux 8 0 0 900 900 0 0
aux 9 0 0 900 900 0 0
aux 10 0 0 900 900 0 0
aux 11 0 0 900 900 0 0
aux 12 0 0 900 900 0 0
aux 13 0 0 900 900 0 0
aux 14 0 0 900 900 0 0
aux 15 0 0 900 900 0 0
aux 16 0 0 900 900 0 0
aux 17 0 0 900 900 0 0
aux 18 0 0 900 900 0 0
aux 19 0 0 900 900 0 0
Kod: Zaznacz cały
# master
set acc_calibration = 124,-37,-264,1
set serialrx_provider = SRXL2
set align_board_yaw = 90
set bat_capacity = 2200
set deadband = 3
set yaw_deadband = 3
set pid_process_denom = 4
set osd_vbat_pos = 14570
set osd_link_quality_pos = 14570
set gyro_1_align_yaw = 2700
set name = Q290
Kod: Zaznacz cały
# master
set dyn_notch_width_percent = 0
set dyn_notch_q = 200
set dyn_notch_min_hz = 90
set acc_calibration = -270,333,53,1
set mag_hardware = NONE
set baro_hardware = NONE
set rssi_channel = 7
set serialrx_provider = CRSF
set dshot_bidir = ON
set motor_pwm_protocol = DSHOT300
set osd_warn_batt_not_full = OFF
set osd_warn_crash_flip = OFF
set osd_warn_esc_fail = OFF
set osd_warn_core_temp = OFF
set osd_warn_rc_smoothing = OFF
set osd_warn_fail_safe = OFF
set osd_warn_launch_control = OFF
set osd_warn_no_gps_rescue = OFF
set osd_warn_gps_rescue_disabled = OFF
set osd_warn_rssi = ON
set osd_vbat_pos = 2433
set osd_rssi_pos = 2073
set osd_link_quality_pos = 2103
set osd_tim_2_pos = 2455
set osd_craft_name_pos = 2049
set vtx_band = 5
set vtx_channel = 1
set vtx_power = 4
set vtx_freq = 5658
set gyro_rpm_notch_harmonics = 1
set name = karcio
LechuW pisze:Mam wolny Uart 1 i tam mógłby być.
Czy jest gdzieś jakiś dobry tutorial jak to ustawić w spektrum ?
Użytkownicy przeglądający to forum: Google [Bot] i 3 gości
