HobbyKing - BlueSeries 40A
Bez nich ani rusz!
GRACZ76
Postautor: GRACZ76 » 31 mar 2012, o 14:12
Witam
Czy ktoś ma wiedzę / instrukcję pl./ jak zaprogramować to cuś /Regulator HobbyKing 40A BlueSeries/
______________________
Pozdrawiam-Grzegorz
Align T-Rex 550 E
Spektrum DX7s
Phoenix RC
Postautor: AdamskY » 31 mar 2012, o 14:44
czesc,
luknij na to
HobbyKing Programming card for BlueSeries Brushless Speed Controller
programowanie regla przy pomocy tego programatora to bajka.
a jak coś to pytaj :-)
GRACZ76
Postautor: GRACZ76 » 31 mar 2012, o 15:50
Jeśli chcesz mi podrzucić to cacko to w padaj :D
Czekam na jakąś pod powiedz co do ustawienia tej piszczałki ;)
Pozdrawiam-Grzegorz
Align T-Rex 550 E
Spektrum DX7s
Phoenix RC
Postautor: AdamskY » 31 mar 2012, o 18:11
ZTW Brushless ESC Program Card Instructions
Programming card use and features:
This programming card can be used to quickly an intuitively setup ZTW’s Brushless Electronic
Speed Controller parameter setting.
Specifications:
1. Dimensions: 49mm (length) * 30mm (width)
2. Weight: 6.5 grams
Programming note
Move the jumper caps located on either side of the programming card to change the desired
parameters in the ESC. For example, to change the motor spin direction, move the ‘Rotation’
jumper cap from Normal to Reverse.
A) When using ZTW ESC with built-in BEC
1. First, disconnect the main power pack from the ESC.
2. Disconnect the BEC cable of the ESC (trio wires) from your receiver and connect it to the
program card with the 3 prong output at the top of the ESC. Make sure the polarity is correct
when making this connection (-ve connects to the black or brown wire). See diagram 1 below.
3. Move the jumper cap to the desired setting of the corresponding parameter you would like to
change.
4. Connect the main power pack to the ESC. You will hear a long audio tone which informs you
that the parameters have been stored to the ESC.
5. Again, disconnect the power from the ESC to confirm your changes.
B) When using ZTW ESC with no built-in BEC (OPTO)
If the ESC is marked as “OPTO”, that means this ESC does not have a built-in BEC. You will
have to use an additional battery pack (4.8V-6.0V) to power the program card. A receiver
battery pack is usually a good choice.
program card with the 3 prong output. Make sure the polarity is correct when making this
connection (-ve connects to the black or brown wire). See diagram 2 below.
change.
4. Connect the battery pack to the 2 prong output at the top of the ESC. Again, ensure the
polarity is correct when inserting the battery pack plug.
5. Connect the main power pack to the ESC. You will hear a long audio tone which informs you
6. Again, disconnect the power from the ESC to confirm your changes.
Note: The programming sequence for ESC with built-in BEC:
Note: The programming sequence for ESC with no built-in BEC (OPTO):
Connect ESC to programming card ---- --- select function parameters ---- ---- connect power to the ESC ----
---- ESC motor power issued a "drop" long audio tone ---- ---- Disconnect power to the ESC ---- ----
Programming is completed
Connect ESC to programming card ---- ---- Programming Card power supply ---- ---- select function
parameters ---- ---- connect power to the ESC ---- ---- Motor issued a "drop" long audio tone ---- ----
Disconnect power to the ESC ---- ---- Programming is completed
jak masz albo bedziesz mial to ustaw tak jak na zdjeciu wyzej
Postautor: Gmeracz » 31 mar 2012, o 23:24
Sorki, ale tak długiego manuala do regla to w życiu nie widziałem....
Chyba za krótko żyję... (z czym się zgodzą moi ulubieni oportuniści) ;)
Czy oni już na prawdę stracili umiejętność kopiowania dobrych rozwiązań?
Postautor: AdamskY » 1 kwie 2012, o 01:51
Gmeracz pisze:Sorki, ale tak długiego manuala do regla to w życiu nie widziałem....
Wlasnie dlatego ten manual skopiowalem ze strony HK , i jak tu ma sobie poczatkujacy poradzic samemu ?pamietam jak kiedys probowalem z apki zaprogramowac regla na poczatku przygody z Heli.
musialem kupic nowy i dalem do zaprogramowania .
GRACZ76
Postautor: GRACZ76 » 1 kwie 2012, o 16:03
No pięknie.Czyli mowa jest krótka,bez tej płytki ręcznego ustawiania czyli drążek gazu góra,dół,środek czy jakoś tak nie polecacie ? :shock:
Pozdrawiam-Grzegorz
Align T-Rex 550 E
Spektrum DX7s
Phoenix RC
Postautor: Ramotny » 1 kwie 2012, o 17:57
GRACZ76 pisze:No pięknie.Czyli mowa jest krótka,bez tej płytki ręcznego ustawiania czyli drążek gazu góra,dół,środek czy jakoś tak nie polecacie ? :shock:
Każda metoda jest dobra o ile pozwala osiągnąć cel... drążkiem to zabawa dla cieprpliwych... i nie zawsze wszystko można ustawić.
GRACZ76
Postautor: GRACZ76 » 2 kwie 2012, o 19:50
Chłopaki, ja nie jestem żadnym muzykiem może słoń stanął mi na.... ,normalnie nie wiem nie u mię ,nie nie znam się .
Stoję w miejscu,zawiesiłem się --------------------------------------------------. :masakra:
ps.może jest tu jakiś muzyk co by mi to po ustawiał ?
Pozdrawiam-Grzegorz
Align T-Rex 550 E
Spektrum DX7s
Phoenix RC
Postautor: AdamskY » 2 kwie 2012, o 20:38
pomalutku, cierpliwosci.
Moja rada jest taka: zakup ten programator i pójdzie jak z górki, programowanie przy pomocy drążka to wyższa bajka i jak pisał Grzegorz nie zawsze się udaje i daje oczekiwane rezultaty.
A ten programator to kosztuje grosze i będziesz mógł go używać tez do innych regli tej samej serii.
PS: ja mam taki ----> Program Box Hobbywing
podpinam go pod PC, pod niego regiel 20 sek i all ustawione, (taka modernizacja we wsi i w zagrodzie :vhappy: )
Postautor: jedrus » 3 kwie 2012, o 03:25
GRACZ76 - mam taki nowy programator za te całe 3,5$ - leży i się kuży - jak chcesz to mogę Ci go odsprzedać po kosztach. Jeżeli jestes zaintresowany to daj znać na PW
Postautor: tomek68 » 3 kwie 2012, o 11:25
mniej więcej tak :grin2:
GRACZ76
Postautor: GRACZ76 » 3 kwie 2012, o 17:52
Panie i panowie ,spiąłem poślady i moc jest ze mną Uuuuuuu :D .Jak mus to mus trochę klikania i znalazłem instrukcję . http://www.hobbyking.com/hobbyking/foru ... ?TID=11284
:juppi: :juppi: :juppi:
Wszystkim dziękuje za kibicowanie :juppi:
Pozdrawiam-Grzegorz
Align T-Rex 550 E
Spektrum DX7s
Phoenix RC
Postautor: AdamskY » 3 kwie 2012, o 18:01
GRACZ76 pisze:Panie i panowie ,spiąłem poślady i moc jest ze mną Uuuuuuu :D .Jak mus to mus trochę klikania i znalazłem instrukcję . http://www.hobbyking.com/hobbyking/foru ... ?TID=11284
no to super :-) i powodzenia...
...teraz tylko załóż pampersa, bo przy takim programowaniu idzie się zes...ac ze złości :vhappy: <joke>
GRACZ76
Postautor: GRACZ76 » 3 kwie 2012, o 19:40
:kopara: :kopara:
Sokoro tak mówisz,to pewnie coś o tym wiesz? :klamca:
Ale ok, jedrus kopsnie mi to cacko i w tedy zobaczymy, AdamskY :)
Pozdrawiam-Grzegorz
Align T-Rex 550 E
Spektrum DX7s
Phoenix RC
Postautor: AdamskY » 3 kwie 2012, o 20:34
GRACZ76 pisze:Ale ok, jedrus kopsnie mi to cacko i w tedy zobaczymy, AdamskY :)
dobry wybór :juppi:
Wróć do „Regulatory obrotów”
