ciosany pisze:Dziękować,już myślałem że z nim coś nie tak.
Blugolf pisze:fakt jest pokazane jak po kolei ustawić ale po ustawieniu nikt nie sprawdza już kątów.
Collective Pitch Dampening (default 50)
Dampens the ascend/descend maneuvers. The higher the value, the smoother the stopping action during ascend or descends. Lower value translates to more direct feel. Recommend setting suitable dampening value to prevent oscillation effect during sudden stops.
Cyclic Pitch Dampening (default 50)
Aileron and elevator dampening. The more dampening value, the smoother the flight maneuvers. Opposite setting will result in more direct flight maneuvers. We recommend selling a suitable value to prevent oscillation during sudden stops.
Collective Pitch Acceleration (default 0)
Can increase collective pitch control speed. Proper setting of this parameter will result in more agile ascend and descend maneuvers, with increased power feel. But this selling will increase servo load. If setting beyond 50% the BEC may not sustain the burst power demand. Recommend using direct power source for the servos.
Cyclic Pitch Acceleration (default 0)
Activating simulated flybar can accelerate aileron and elevator control speed. Suitable setting value can provide smoother cyclic pitch control, but may also create slight acceleration during hover. Therefore is not recommended for beginners. Generally it can be set to 30 to 50%.
